5.3 Cam and Pedal
Old May 17, 2016 | 10:12 PM
55 pu man's Avatar
Default 5.3 Cam and Pedal
I have an 08 5.3 in my 55 chevy pick up. I have a few questions. 1st does anyone know if i can use an 05 pedal instead of the cheap plastic arm and pedal from an 08? It's made of metal and i need to cut it up and weld something to it at a better angle with new pedal. Seems to be same wiring but different plugs. I can swap a plug easy enough. 2nd should i put a z06 cam in this motor and will it fit? I've heard it was a nice upgrade and i have an opportunity to get a take out pretty reasonable. Maybe the intake too if it will fit. They are out of a LS7. I'm a LS rookie so kinda in the weeds..
