How to check pcm alternator control
Any ideas are appreciated.
OK, Looked at RA------
That looks like the same pulley that comes on the alternators that I have now ? You can turn the pulley one way and it spins the alt and turn it the other way and it just slips.
Thanks for the info!!
. OR has a good warranty so I can just take it back and swap it out. Taking it off the car is a pain in the butt. It's down at the bottom, but has to come out the top. Drain radiator, take off intake tube, take off top radiator hose, remove fans---then I have less than a 1/4 inch clearance from the oversize radiator to get it out. I have heard something about a diode or
resistor to keep it from doing something like that
Can you put an analogue gauge off of the alt to check voltage temporarily in your car and watch
What happens at high RPM.
I'm just thinking on the keyboard.
