LY5, LS1 interchangeable?
Old Sep 23, 2016 | 10:41 AM
ls1charged's Avatar
Default LY5, LS1 interchangeable?
Is anything off of a 99 ls1 (intake, cam, accesories, heads) interchangeable with a LY5? did some searching and didnt find much results? i know its a 4th gen block but i want to know what ill have to do to make the swap as least painful as possible. thanks
Old Sep 23, 2016 | 12:00 PM
JoeNova's Avatar
Restricted User
Basically everything except the pistons will fit. The alternator bracket is the only other thing that will cause problems. The iron blocks didn't have the holes drilled/tapped, so you will have to do it yourself. Not a big deal.
