coil packs
We have all the LS-x coil family, our improved version. (10%)
The BEST best choice for MAX Power is the IGN-1A kit.
What is you Expected HP/Future HP ?
Typically the IGN-1A kit will produce 18 HP increase on a 500 HP engine.
This coil kit is reported by users the increase fuel millage.
This is the SAME coil REQUIRED for NHRA Pro-Stock competition.
Lance, BTW we supply the Summit/Atech "store brand".
The Denso 580/585 coil has a Dwell Staller "safety" feature @ 5ms Dwell.
NEXT question : The BEST coils ARE Made In China, even the US LAW "states" NOT TO REMOVE that Label unless sold as part of a kit, not with case shipments.
REASON : They have the most Rare Earth materials, low grade steel, (good for coil magnetic effects), and costs.
OUR factory, in China, is ONLY for OUR production, ALL with US Standards and Engineering.
Most of the production is for EOM's
Lance
I have an L92 motor and I cannot seem to find a price for the IGN-1A kit. I would appreciate someone to PM me the price. I am also running the Holley valve covers that the coils bolt right to the valve cover with 72mm bolt spacing for the stock coils. Looks like I would have to make a couple of brackets for this to work.
Edit: I live in Cypress, Ca so I am in driving distance to Santa Ana where Pantera is located.
Brackets will need to be cut/welded/modified. I think I can just hack off some of the points and reweld them to fit the holley.
The key is "off" and as we know many items are in operation, the clock is one such item.
A "charger" with high voltage, +17 volts, could cause a problem.
MANY electrical items have "clamp" diodes for their protection as do my coils.
The IGN-1A coil has an internal "clamp" Zener @ 18 volts.
This device helps in many ways, one such is to protect the EMS.
The need to "disconnect" is not true UNLESS you try to start the car with the charger connected.
NEVER A GOOD METHOD in ALL CASES
Thanks for the request, if you have the Valve Covers that fit the Holley NHRA required Pro-Stock coil, the kit cost would be less.
This is the IGN-1A coil.
The stock coils ?
This could be a new bracket design for me to create, just a "water jetted" S/S item.
You are welcome to visit my shop, I am near John Wayne Airport, just off Dyer Road.
Call for an appointment, or PM me your phone # and I will call.
You could bring a Valve Cover and inspect coil fit ?
Lance
