Truck harness to ls2 throttle body
I have a ls motor im swapping into my 67 chevelle its a ls1 with ls2 top end(intake,throttle body, and fuel rails/injectors) I already have the truck pedal and tac module along with the ls2 parts. Getting closer to the end of the motor swap I started looking at the connectors and noticed the truck has a 8 pin on the harness and the throttle body is a 6 pin. After doing research with no clear conclusion im left here confused as to whether or not it can work. Can you adapt the truck 8 pin throttle body connector on the harness to the 6 pin silver blade ls2 throttle body I purchased. Ive seen the xlink mentioned once but I would like to not spend that money if at all necessary.
You will have to have the x link . No way around it if you use that t/b . You could run the truck throttle body if the smaller 78mm t/b is not a problem for you . You will have to have a 4 bolt to 3 bolt spacer to get it to bolt on .
I have the x link and works perfect on my set up .
