Modified LSA FEAD
Old Apr 16, 2017 | 02:11 AM
mitch70's Avatar
Default Modified LSA FEAD
Hi Guys.
Im building a cobra with narrow chassis rails.
I've had my modified LSA FEAD on back order from summit for well over 4 months now with still no date of supply, its holding up my build somewhat now. It appears normal FEAD are available.
I found an old article using an LS7 bracket to raise the alternator, but wondered if you guys had any advice as I assume other items will need changing. I can see other cars use the LS3 high alternator bracket set up are they interchangeable?
all advice gratefully received.
Thanks and regards Mark
Old Apr 30, 2017 | 06:09 PM
rpturbo's Avatar
PM sent. Can't break forum rules and post links up for other things.
