Looking for injector recommendation.
I installed a Megasquirt MS3Pro with their drop-on harness.
Currently have a ported LS3 intake with cable TB, JTR 1-7/8 Longtubes, with 3" X-pipe and duals. Injectors are LS3 42#/hr.
Got it dynoed last week and it only made 525rwhp. I was expecting a bit more, and when I got it on the road it is WAY DOWN on power and throttle response from when it had the tuned GM pcm.
I sold the GM pcm, so am unable to read the old tune. If I had known earlier about the local dyno tuner, I'd have had it baselined before I did the swap.
Big problem though, is the injector duty cycle greatly exceeded 100% on the dyno, even though AFR's were good. It even hit slightly over 100% in street testing.
Obviously, I need to upgrade injectors before I go back for another tuning session, and would like suggestions on the best brand and size to use. Cost is a consideration, but not the only consideration.
Also, what are the largest injectors that would give a good idle and drivability with my combo?
I'd like a bit more headroom for when I later rebuild the motor, with more head work, and possibly a supercharger.
Thanks in advance,
David
What's your peak RPM, you would benefit from FAST 102
With Mid-Length Runners over 6000 RPM with your LONG Stroke.
Pattern and are not optimal for NA. A 450 LPH Wallbro pump
Would work ideal and have room for blower down the road.
I read the same thing about the ls9 injectors. I was pretty bummed.
Lots of info on the Megasquirt/MS extra engine management owners group on facebook as well in case you arent there already.
I run Fuel Injector Development 850s (~1000cc@60psi) with my ms3pro and they have worked extremely well for me with dry nitrous application. Injector duty cycle is extremely low, allowing injector phasing for more power.
I'm already on the MS forum, but thought there'd be more LS-specific experience here.
Thanks.
