I need coils, oem or what?
Old Sep 2, 2017 | 02:22 PM
Bowtiejoni's Avatar
Default I need coils, oem or what?
What coils do you recomend for n/a 415 ls3?
Old Sep 2, 2017 | 02:49 PM
OEM ones work quite well.
Old Sep 2, 2017 | 02:55 PM
KILLERARMY's Avatar
Read the thread from Paul Bell about ignition coil choices.
https://ls1tech.com/forums/generatio...l-upgrade.html
Old Sep 2, 2017 | 03:20 PM
A good read! Mainly says that the OEM TRUCK coils (the "round" ones) show a bit of an edge in hotter spark.
So I was half right; still OEM, but TRUCK coils are the trick move here.
Old Sep 3, 2017 | 10:05 AM
pantera_efi's Avatar
Default Ignition Coil Installation & Tech
Hi Joni, the "best" choice is based on cylinder pressure/fuel/max RPM for the requirement.
The next consideration is cost/HP increase/fuel mileage increase/throttle response.
The world wide accepted choice (any engine) is my IGN-1A coil for Maximum Performance.
This coil if fitted will produce 18-22 HP over the LS coils AND reduce fuel consumption with an increase in throttle response.
This case requires two sub-harness replacement, two brackets, new SPW, and tune.
The next choice is my GEN-IV coil with heat sink, an 85mj coil.
This coil will fit your LS-3 native brackets, wiring, SPW if correct information was provided.
NOW even the BEST COIL/ANY COIL will require a Coil Dwell modification in the EMS tune for best performance.
When the coil can "keep-up" you can increase SPG with results in more HP/lower fuel consumed/better throttle response.
Would you like more information ?
Lance
