6.0 iron block...extra hole in block by knock sensor?..help
Old Sep 17, 2017 | 10:35 AM
stepuptata's Avatar
Default 6.0 iron block...extra hole in block by knock sensor?..help
Anyone know what this hole is for? Just installed the engine and just noticed it. At first thought it was the dip stick hole.
Its not threaded . It's the hole just to the left of the knock sensor threaded hole
Old Sep 17, 2017 | 11:02 AM
The dipstick tube is a tight push fit into the hole. I've never seen a threaded dipstick hole yet.
Old Sep 17, 2017 | 12:49 PM
stepuptata's Avatar
It's not for the dip...dip hole is in the pan...this hole is in the block
Old Sep 17, 2017 | 12:56 PM
1FastBrick's Avatar
That's a dip stick hole for a truck application.
Old Sep 17, 2017 | 01:05 PM
stepuptata's Avatar
Oh
mske sense
now what can I do
2 dip sticks lol
Old Sep 17, 2017 | 01:07 PM
1FastBrick's Avatar
Plug it. Maybe silicon in a vacuum nipple???
Old Sep 17, 2017 | 01:11 PM
stepuptata's Avatar
Think RTV sealer??
Old Sep 17, 2017 | 01:14 PM
1FastBrick's Avatar
Yeah, i would probally try to fit something like a vacuum nipple in with some RTV
Old Sep 19, 2017 | 01:19 PM
dw456post's Avatar
Gm makes a metal freeze plug type plug for that hole. I have one in my aluminum block.
Old Sep 19, 2017 | 01:26 PM
Whatever you do, it has to be sealed up or the PCV system won't work right.
Old Sep 20, 2017 | 09:52 AM
KCS's Avatar
KCS
Moderator
I think they're in the G8 V8 blocks too since the dipstick is in the oil pan.
Old Sep 20, 2017 | 06:09 PM
1FastBrick's Avatar
Does this Sound right??? I wonder if this is the correct size for an LS block???
12557520 PLUG,OIL LVL IND TUBE HOLE(CUP-.390IN OD,.040IN THK,STEEL)
Old Sep 21, 2017 | 09:51 AM
KCS's Avatar
KCS
Moderator
Yeah, that sounds like it's it. Good find.
