LS7 Rocker Arms
Old Nov 14, 2017 | 01:57 PM
KW Baraka's Avatar
Default LS7 Rocker Arms
Anyone know the max recommended lift for OEM LS7 Rockers?
Thanks!
KW
Old Nov 16, 2017 | 03:37 PM
Double06's Avatar
From what I have heard the range is like 640 to 660 lift.
Old Nov 16, 2017 | 04:26 PM
David@Vengeance's Avatar
We have run upwards of .685" lift on OEM rocker arms and trunions. That being said, it really depends more on your lifter/spring combo as to what lift the valvetrain can handle. If we can assist with any camshafts or valvetrain components please let me know and I'll be happy to help!
- David @ Vengeance
Old Nov 17, 2017 | 11:13 PM
KW Baraka's Avatar
These are CHE rockers (OEM with their bushings). I called CHE on Wednesday and they said right abound .650"....above that and 'all bets are off'.
Originally Posted by David@Vengeance
We have run upwards of .685" lift on OEM rocker arms and trunions. That being said, it really depends more on your lifter/spring combo as to what lift the valvetrain can handle.....
Thanks David.....and I'll keep you guys in mind!!
KW
Old Nov 19, 2017 | 10:42 AM
pantera_efi's Avatar
Default Che ls-7
Hi All, I too agree with the CHE tech AND the use a Lash Cap on each valve would help.
I also fit their Rocker Arm Studs.
Lance
