Burnt motor
Old Nov 21, 2017 | 08:22 PM
a70oldscutlass's Avatar
Default Burnt motor
I found a 2011 Camaro that burnt and I can buy the motor for $400 and was wondering if anybody has used a burnt longblock and if so did you have any problems with it.I also need to know how much it will cost to put a intake and all the pieces back on it to get it running again because I'm sure everything was burnt.I will be putting a cam in it so all the seals and gaskets will be replaced.It will go in my 1970 442.thanks
I can also buy a 2000 6.0 for$400 that runs.Which would be better.
Old Nov 23, 2017 | 11:16 PM
Crf450r420's Avatar
The second one would be much cheaper and probably for the money saved could make more power than the first one. Intake and injectors alone are $500 and up. New seals everywhere and the balancer has a rubber ring. This is just if it wasn't running and the intake didn't melt down into the one or two open intake valves.
