427 intake manifold options
I would spin it higher than 7000 if I could get enough intake manifold on it.
7500 RPM.
Hammer & I both utilized Mid Length Runners with LS3 Style Heads
That peak about 7200 & Carry to 7800 with 3.60" & 3.622" Strokes.
4.0" Stroke has ~ 10% greater piston speed at the same RPM.
7500 RPM with your 4" Stroke = 8250 in ours.
So at the track shifting over 7500 the Short Race Runners would
Be the way to go and Mids if you drive on the street.
The runners are relatively inexpensive and easy enough to swap
Out and test for yourself.
Now I went to a 105 Holley TB and ported the intake inlet to 107 as I was getting a touch of plenum vacuum at high rpm. This does eliminate the oring gasket though, but the 105 comes with a paper gasket and I fogged it good with high tack.
If you're working around the cowl on an fbody then the fast is the easiest and most versatile IMO
if you ever want to try the shorter runners, you can! That's the beauty
I mistakenly thought the manifold texas speed has on the site was with the race runners when it actually has the mid length runners.
The race runners in the Fast don't look much different in length to the runners on the low profile Holley manifold. Holleys runners are straight which I prefer. Cost really isn't the issue here even though the Holley is a good bit less expensive. I just wish knew someone who has used the Holley in a big inch n/a with nitrous application.
KW
