GM Engine Controller Kit, CAN bus?
Old Dec 20, 2017 | 05:52 PM
sputni042's Avatar
Default GM Engine Controller Kit, CAN bus?
I’m in the final stages of preparation for a Porsche 996 LS swap and have a question for you all. I’m planning to run the LS376/525 crate with the GM Controller kit (19354332) and in an effort to avoid some excessive dash wiring, I would like to utilize the Racepak IQ3 display dash through OBDII. Here’s the question: Racepak says their OBDII connection only works with ECMs that are 2008 and newer, since this is a crate there’s obviously no model year, so does anyone know if the GM Controller has a CAN bus and will work with this setup? Also, is anyone running this setup?
Thank you all in advance,
Eric
Old Dec 23, 2017 | 09:37 AM
pantera_efi's Avatar
Default J-1850
Hi Eric, the 2008+ GM CAN 2.0B uses a different word format , SAE 15765.
I would ask GMPP about the word Format.
Lance
Old Dec 26, 2017 | 04:06 PM
Project GatTagO's Avatar
I believe the GMPP kits use the e67 ECU using a custom OS. My kit referenced a 2006 CTSV ECU. I got my kit in 2008, so I have no idea what GM has done since then.
Andrew
