LS1 to LS2 Throttle Body coolant lines?
Hello forum
I am swapping the intake manifold as well as the throttle body on my c5 base, and I know the LS1 throttle body has a coolant line on body sides. The LS2 throttle body does not have any coolant lines. Should I just connect both the coolant lines together that connect to the ls1 TB?
Thanks!
Thanks!
Either that or cap them where they originate.
As said. These were mainly intended for cold climate, but them together or replace the line and run direct from the steam ports to the radiator.
