water pump/MSD intake problem
Location: Grew up in Charleston, SC live in Moncure, NC
Update. The Edelbrock 8896 water pump fit perfect. No mods whatsoever. Only thing required is a 0.210" spacer to match the Vintage system. I'm going to fabricate a spacer to put behind the pulley. Also, the pulley that comes with the Vintage set will work with the Eddy. Bolt hole pattern same, etc.
In summary, the water pump supplied with the Vintage LS Front Runner system will not work with an MSD intake. But the Edelbrock 8896 fits perfect...
I just finished up installing all of the front runner stuff. I will post some pictures later.
I did however run into some more problems. As stated earlier, the new pump fit perfectly with the MSD/NW 102. But, the main bracket in the VA package - the one that ties everything together did not clear the Edelbrock pump very well. I final got it to work, but had to do a lot of cutting and grinding on the bracket. It turned out great - but had me cussing for a bit...
A couple of pictures. You can see in the one photo the grinding/cutting I had to do on the bracket. Luckily, almost all of it is on the backside facing the engine. You have to look hard to see anything on the front. And if I had been more patient, you wouldn't notice anything.
The other two photos show the 0.210" spacer I made to put behind the pulley.
