C5 intake adequate for a cammed LS3?
Will the stock 2000 MAF and ducting restrict the engine that badly? Currently I have a dual cone intake in front of the stock MAF but can also use a Zip Tie modded stock duct if need be.
I had a 4" intake pipe on my 6.0 BMW running a small cam and an Express Van PCM and it was a bear to tune, according to my tuner.
I'm right behind you with the LS3 swap. I went with a ls7 stock induction system and cartridge style MAF sensor Ls2 TB in favor of stock set up. Going to be about a month before I get to a tuner. Keep us imformed....my gut says big restriction stock C5 set up.
license plate area out of the front bumper if you can stomach that aesthetically,
and get away with that with the local gendarmes.
Otherwise ditch the dual snorkel and go VaraRam.
My 414 l92 headed setup is using the 85MM maf, but im also on the 98 ecm. Didnt have issues and while im sure there is still some power on the table with my setup. The cost benefit of it wasnt really there considering what im going for with the car. I was pretty happy with my numbers in the end and I make a lot of torque down low, swapping intakes could change that on my setup with the cam I have. Not exactly apples to apples given the airbox difference bewteen the two, but thats my experience on it. In other words yeah your leaving some on the table but probably not enough to be concerned with unless you are going for absolute max results.
Maybe I'll look into some sort of aftermarket C6 intake such as the Halltech. I just don't want to induce a bunch of tuning headaches by going with a different MAF.
