What damper to use with 416 LS3?
Old Feb 13, 2018 | 01:25 PM
Bowtiejoni's Avatar
Default What damper to use with 416 LS3?
Hello,
Is stock C6 vette or camaro bamper all I need with 4” stroke 416?
Or do I need something more exotic?
Old Feb 13, 2018 | 05:09 PM
NAVYBLUE210's Avatar
From: Coast of San Mateo County Between Pacifica & HMB
How much time & Money do you have in your 416"?
and how high due you plan to spin it?
Old Feb 13, 2018 | 05:22 PM
ATI. Your engine will thank you later.
Old Feb 14, 2018 | 03:59 PM
Bowtiejoni's Avatar
6500 max
Old Feb 14, 2018 | 11:29 PM
KW Baraka's Avatar
I would use the OEM balancer.
But if I went aftermarket, I would use ATI.
KW
Old Feb 17, 2018 | 03:10 PM
Bowtiejoni's Avatar
KW
I am leaning oem as well. Na engne, not high revs
Old Feb 17, 2018 | 06:19 PM
badazz81z28's Avatar
So you took an LS3...Invested time and money into stroking it. I'm sure you have some tasteful internal, head work and a cam....Yet you want to cheap out on probably one of the most vital parts that prevents engine damage? Seriously? Spend the money and get an ATI balancer. What's another $500??
Old Feb 17, 2018 | 10:34 PM
^^^^^^What he said LOL^^^^^^
Old Feb 18, 2018 | 07:02 PM
Jimbo1367's Avatar
^^^^^^^ditto^^^^^^^^^^^
Old Feb 19, 2018 | 02:30 AM
KW Baraka's Avatar
OK....so what's wrong with the OEM balancer?
KW
Old Mar 1, 2018 | 01:10 AM
383z's Avatar
What's wrong with a PowerBond?
Old Mar 1, 2018 | 11:22 AM
pantera_efi's Avatar
Default ATI Dampener Tech
Hi All, My choice is to fit an ATI Dampener with Key Way, reasons below :
1. The ATI dampener has a Key Way as do my/most Forged Crankshafts.
2. The ATI/most custom dampeners also have a Key Way that allows an Index Position MARK to be placed on the OEM crankshaft.
3. The LS engine DOES NOT HAVE TDC "marked" NEEDED for TDC Timing Verification with a Keyed Dampener Index now simple.
4. The installation of a Belted SC REQUIRES a Dampener/Crankshaft Key Way.
5. The Race Track RULES could require a SFI Dampener.
The other above tech is well given.
I ALWAYS fit an ARP dampener bolt, thread coated with Jet Nut, then Torqued to 400 .ft/.lb.
Lance
Old Mar 1, 2018 | 09:50 PM
jebcamaro's Avatar
A 416 LS3 isn't a cheap engine. It would be a no-brainer to go with an ATI dampener after spending all that money on such an engine.
Old Mar 2, 2018 | 01:24 PM
NHRATA01's Avatar
I would use the ATI, having just spent a lot on a longblock myself. A couple hundred extra for an SFI dampener is well worth it.
Old Jul 17, 2018 | 04:45 AM
Robert02's Avatar
I've got a forged 416 with ATI 10% under drive pulley and spin it to 7g no problem
Old Jul 17, 2018 | 10:19 AM
JakeFusion's Avatar
Super Hulk Smash
ATI is a great damper. I spin to 7200 no issue.
Old Jul 17, 2018 | 10:40 AM
xc_SS/RS's Avatar
ATI 10% underdrive for the win. get an ARP bolt as well
Old Oct 24, 2018 | 03:46 PM
Bowtiejoni's Avatar
Thanks guys, ATI it is!
Old Oct 25, 2018 | 07:56 PM
99 Black Bird T/A's Avatar
My 416 got an ATI 10% under dampener.
Never considered anything else.
Had the ATI on the old LS1 with heads & cam, and it definitely revved better with the ATI than the stock set up.
Old Oct 28, 2018 | 11:52 AM
QwkTrip's Avatar
Be sure to ask for 66 durometer rubbers. The ATI 10% underdrive comes with softer rubber that is not sufficient for your engine.
