Gen IV 5.3 to a TR6060...what flywheel?
I’m doing a LS swap into my C10. It’s a Gen IV 5.3 that I plan to mate up to a TR6060 our if a Camaro.
What flywheel works for this? The 5.3 never really was mated to a manual. Does a LS3 flywheel work here?
5.3 to tr6060 flywheel
were u ever able to bolt up the tr6060 to the 5.3 what flywheel did u use?? I tried using the 5.3 flywheel an the 2010 camaros oem cluth kit and the pressure plate wont sit flush to the flywheel
Use the flywheel and clutch from the car the trans came out of. So if the Camaro is a 2012, order items that fit a 2012 Camaro. The cranks are basically all the same except for LSA, LS9, and a few others. Just use the correct pilot bearing, which if I recall, is a large one for later model Camaros.
