Question about CNC-ported LS9 heads
Then when it's all said and done how much more would the new AFR LS3 head be? That is heads and tails better than any GM casting and is roughly $2,600 depending on what options you want.
Best case scenario is finding a used set of already CNC'd LSA heads, but they're few and far between!
I hear you about the guides because of the Ti valves, but on the Corvette Forum I am not seeing the same issues with the LS9 heads that you see with the LS7 heads.
And I hear you about the AFR LS3 heads. I am also considering those, but can't get a bump in compression with those without milling them.
