Help converting LS1 to LS2
Old May 1, 2018 | 08:45 AM
Gettyhumper's Avatar
Default Help converting LS1 to LS2
I'm going to a forged LS2 block replacing the LS1 in my 2003 Corvette. What external engine covers etc do I need that will not fit from the LS1 engine? I will be keeping the LS1 computer, intake and heads.
I will get a 24 tooth reluctor with the forged LS2 bottom end. I know the cam sensor must be on the from cover on the LS2 correct ? and I will need a harness extension to the engine front. Bur are the timing chain and gears different? Oil pump?
But could someone with experience in this change over just list what I will need. Thanks
Old May 1, 2018 | 11:08 AM
You will need the 1X cam sprocket for the cam sensor to read properly. Chain is the same, so is the oil pump.
Old May 2, 2018 | 12:03 PM
pantera_efi's Avatar
Default Timing Set 1/2 Moon + Sensor wiring change
Hi Getty, YES agreed, you will need to fit a 1/2 Moon Cam Timing Sprocket.
I sell the Avon Billet Timing set for a cost of $158.00 + USPS of $10.00 shipping.
YOU WILL NEED to switch the TWO OUTSIDE wires side/side for the NEW front cover sensor. (push-to-seat)
Lance
