Best “cheap” throttle body?
with all the horror stories i came across when looking up what would be a good choice for a TB while trying not to spend 600$ for basically a block of aluminum. They are basically all the same but it does seem that some “people” (read: brand) have a much harder time over others when it comes to measuring out the specs to machine ‘em out for AIT and TPS sensors and the likes....
So,,, beeing there and needing to purchase one myself for my beast, i’ve read...and read and cannot find THE definitive anwser as to if there is ONE brand that can be trusted that will /would be a true “bolt on”.
With all the models available (G-Plus, Summit, Sniper, etc) and in a 92 or 102mm sizing, what are your ACTUAL and personnal (no word of mouth please 😇 ) experiences and which one would you reccommend.
Thanks as always!!
Lead.
He has done CNC manufacturing for my requirement, S-97 twin injector throttle bodies.
I also cast my own TBIs 65mm each for ITB on LS engines.
What size do you request, for a quote ?
Lance
Thanks as always!!
Lead.
They are a direct bolt on and use your sensors.
You WILL need to tweak the sensors to make them work properly.
You WILL need to Loctite the bolts holding the throttle blade on so they don't get sucked into the engine.
Hey Joe, thats what i read but no real actual proof/ details of this as well as having to machine them some, so im left with some “comments” and not much details so its exactly what im trying to cut clear!! I put a lot in the project this year and now have to cut corners a bit where it dont matter too much too be able to enjoy it this summer. I decided to go with the Holley instead of the Fitech (you’ll surely be happy! Lol!!) and a few other good pieces so my budget is suffering!!
some guys had luck and some less with same TB’s. Id be happy just knowing which one has the most chances to run good.
Pantera, as far as size, Im thorn a bit as my Hi Ram has a 105 opening but i might sell it and end up running my TBSS intake and then, id go with 102 or even a 92 as i learned it dont really matter with a Turbo. They all are up to the task it seems.
thanks guy’s.
Lead.
The IAC on them is a mess. The port is tiny, and the openings in the front/back are about half the size of an OEM 3-bolt throttle body. This causes the IAC to suck and whistle. The IAC will sound like darth vader on statup, and be far less effective at controlling idle on a large cam, decel, etc. This can be fixed with a LOT of patience and a die-grinder.
Ahhhh!!! Exactly what ive read!! Im trying to remember as one had a simple solution to this whistling thing or one of them TB’s had it fixed easily... i’d need to check my notes.
Ok, so knowing all those pieces are pretty much in need of some work, would you have an opinion or a reccommendation on what could be a (i know) good purchase while still not paying 5/ 600$? I mean, there are 75$ parts all the way thru ~200$ So maybe ther is one better than the other? You mentionne the WARR unit and i think i read it wasnt that bad?? Im surprised Summit’s parts didnt get these problems fixed before putting their name on em. They usually have quality parts.....and that, coming from a guy that generally NEVER buys these parts (i like renown brand names, as they usually re-sell better and also lose less value) but having been trying em more and more, i tend to appreciate them more also.
Thanks for the help man,
Mario
The Subaru EJ-20 TWIN TURBO JDM was a VERY Hi Performance ride in Japan.
THIS OEM (Fugi Heavy Industries) also fitted a SMALLER TBI Butterfly than in their N/A EJ-20.
This was done to make the car more driveABLE.
This four cylinder would "put down" 300 HP with a displacement of 122 CID. (All OEM)
I WOULD RUN your TBSS intake, far BETTER for Turbo use.
Think "spool" as the Hi Ram use will cause Turbo Lag.
Lance, BTW I manufacture a DBC converstion for the 90mm Air Door ($135.00)
one thing you will run into is a poor flowing IAC passageway on the chinesium throttle bodies. if you want an easier time tuning the idle, get a good throttle body.
https://www.lsxceleration.com/fitech...ody-w-iac-tps/
Opinions? Facts? anyone know anything about these?
They don't make them or have ever had anything to do with their design/manufacture.
That throttle body is a better design than the typical China throttle bodies, but I don't think anyone has tested them.
It comes with all the necessary provisions.
It's been nothing but a pleasure to use, so far. Plug and play, with minor adjustments to the TB Screw to get a smooth idle.
No drilling holes, no other drama.
