Error code issues
Old May 7, 2018 | 03:40 PM
98pontiacfirehawk's Avatar
Default Error code issues
I have a 2011 Camaro ss LS3. I drove to the store and back she was idling when I was inside went back out the car wasn't running. Start it up it was missing engine light flashing seemed to be in limp mode. wouldn't idle. Codes are P1101 and P0113. Changed out MAF and IAT sensor same thing. Thinking something related to throttle body isn't sync or something. Did a live data with engine not running and not touching the pedal the TPS 30.2%TPS B is 29.8 Rel TPS 16.1% ACC Pedal D is at 19.2 ACC E pedal 9.4 Command TAC 23.9. To the floor it shows TPS 83.9% TPS B 83.9 Rel TPS 70.6 ACC pedal D 83.1 ACC Pedal E 41.2 Command TAC 100.0
I know that generic code P1101 is not exact to what? I have no idea? Have to wait on everything to order for this cars since no one carries **** on hand. Any help would be helpful, I don't want to go out and spend hundreds on parts knowing what part is bad? Thanks guys
Old May 15, 2018 | 06:16 PM
It was a broken valve spring creating the issues guys. Couldn't tell due to the charger. The ECM wasn't getting the correct number crunching throwing the code P1101. Good info to know. Cheap *** valve springs.
