Will the cast oil pan on an LS3 support it's weight ?
Old Sep 23, 2018 | 08:37 PM
snomo's Avatar
Default Will the cast oil pan on an LS3 support it's weight ?
Need to move my LS3 an inch forward - can I support it using the cast oil pan for the 15 or so minutes that it will take ?
Old Sep 23, 2018 | 08:40 PM
If you support it on a FLAT surface you should be OK
Old Sep 24, 2018 | 11:13 AM
00pooterSS's Avatar
Yep ^^
Should be fine, I've jacked up several LS motors by the oil pan.
USE A WOOD BLOCK that goes from one side of the pan to the other to help distribute the weight across as much of the pan as possible.
I use a 2x4 when I do them and it works out great, I do it mostly when I'm replacing engine mounts.
Old Sep 24, 2018 | 02:32 PM
Kfxguy's Avatar
Whatever you do, do not jack it up with the metal part of the jack pad.
Old Sep 24, 2018 | 02:56 PM
^^^^^^^^This!^^^^^^^^ ALWAYS use a piece of wood or other relatively soft material. And NO pressure points. Use as much area of the pan bottom as possible.
