Piston Help
Old Oct 16, 2018 | 10:45 AM
MechMan1's Avatar
Default Piston Help
Can anyone help guide me on the correct piston to choose for my LS3 build? I am looking to at the very least stay at stock compression but thinking about goinig up to 11:1. IS negative numbers best for boosting compression or is positive? I am using the Wallaceracing compression calculator but have been told the the piston values should be reversed. any guidance with this would be most appreciated.
Old Oct 16, 2018 | 12:08 PM
Give a call to WS6store, a vendor/sponsor here. They will help you with whatever you need
Old Oct 16, 2018 | 06:36 PM
s30.hybrid's Avatar
You gotta be careful of how the piston CCs are advertised as I’ve seen them listed both ways. For instance, if you look at a dished piston it may be listed as a -15cc but in reality it will net +CC to your combustion chamber. And another manufacturer may list the same sized dish piston as +15cc (this is the correct meothod IMO).
In general, a dished piston will add combustion chamber volume. A domed position will decrease combustion chamber volume. And a flat top piston will net a 0cc change. But it’s best to verify with the specific piston mfr.
