Pulling engine not trans, but.......
Old Dec 27, 2018 | 11:04 PM
2010Imperial's Avatar
Default Pulling engine not trans, but.......
Like title says. Engine is ready to come out. But the engine is froze. It won't turn over so I can get the torque converter bolts out. That is all that is left to do. The whole top end is off. I busted a piston due to hydro lock. Any ideas?
Old Dec 27, 2018 | 11:38 PM
If you get the engine unbolted from the tranny, is there enough room to slide the engine forward enough to pull the torque converter out of the tranny? If you removed the radiator/condenser already there should be enough room. Either that or pull both the engine and tranny in one piece.
