Thinking out loud... MSD LS7 vs FAST LS3 Med Runner
#44
Thinking out loud...CID intake has shorter runners and larger plenum. What are other intakes missing as far as power? Plenum, runner length, CFM=Larger TB. Take any intake talked about and ask what does a larger TB do for a given combination? If a 105mm TB is good then a 108+mm is even better. Same as a 4500 vs a 105mm TB. Size maters. This isn't carb 101, We can never have enough air flow with efi & tb. No matter runner length.
#45
Moderator
Received 1,836 Likes
https://ls1tech.com/forums/showpost....&postcount=465
That is for the cathedral head test thread. Still looking for the Rectangle port thread...
#46
Moderator
https://ls1tech.com/forums/generatio...fast-lsxr.html
Here is the Gen4 thread, but fewer manifolds tested.
#47
Holley Low Pro sniper and Mamo's MSD Ls7 needs to be tested next with & without heads attached. So as to see the 400+cfm numbers get Choked? 370cfm from a MSD runner would be funny. Cut and reweld the low pro for a larger TB face 105+mm not a 102. More area: has more potential cfm which is always needed. Out think the intake? Plastic can be cut but Not welded for a larger face.
#48
The entire key to power is having a head that isn't hindered by a choke point. Whether intake or TB. If a intake only flows 330 but my heads flow 370+ = lost potential! Just got a text back from D. Morgan on LT1 heads. Says's it's a bastardized abortion case best talked over the phone. Damn that bad?
#49
Moderator
As to what needs to be tested, dude was covering the costs himself. I know a few of us kicked over some $$$ to contribute, but I guarantee you he paid over 90% of the cost. As to the intakes, he just needs them sent to him. Most people that have a mamo LS7 MSD have it sitting about 4mm above their valley cover, so there aren't many laying around for posterity.
If Darrin says you have a bastardized abortion case on your hand, You may want a few drinks before you call him...
#50
Not saying one must do it. But a thought as to Know what is seen with the intake attached. 380 + cfm heads. I'll see what Darin say's, if rpm and higher lift don't get a little something. Move on but would like Darin's thoughts as to why the head is a abortion case. I'd like to see what you and Hammer heads flow with the Low pro attached.
#58
Moderator
#60
