MAF delete with a painless perf. harness
Old Mar 13, 2019 | 07:41 PM
33coupe's Avatar
Default MAF delete with a painless perf. harness
want to delete the MAF and use just a MAP on a very mild LS2 6.0 with a holley hi ram and 2 throttle bodies mostly for looks as it is a street rod. The harness has 5 wires in the connector to the MAF/IAT. I want to use the IAT in the throttlebody {holley} but am unsure which 2 wire colors I need for the sensor. Also do I just tape off the MAF wires and leave them in the harness. Thanks in advance.
Old Jul 11, 2019 | 07:21 PM
Mista Blazer's Avatar
not sure what the colors of your harness are but this should get you close to the pinout as the LQ4 should be a 5pin as well
https://ls1tech.com/forums/conversio...fferences.html
