411 LS3 head recommendation
F it just spend $. Theme.... BS.
Key is obviously the right Cam Guy, I have been very happy with Steven @ Cam Motion.
But ..... If you want to spend the money.... MMS LS3 Heads >265 CC flow better than all heads
mentioned sofar.
mentioned sofar.
Larger factory ports like the one used would Llike Lift & Key along with intake chosen = Carb style would work out BEST. CID intake.
262/280 duration 780 lift with a 112lsa+2 less duration would kill the 8000 peak. 4 ref. i use a 270@ .050 & 115lsa 110 intake centerline to get to a 8k peak
I've not been inpressed with none of the aftermarket Ls3 heads or the combos. Only thing is dyno numbers which don't mean nothing except you got power. 2 many 600rwhp+ dyno runs and 10's and at best 9.6's aftermarket Ls7 heads included. Funny thing is ask 1 of the guys like hammer how much he has invested in those heads .... Being Mast with Tony's work for a higher rpm build... Still say the car would have been faster with more stroke. But rather be different than faster . You can do what you want. I do what i'm told on how to make hp and a et. Take the same 416 place it in Hammer's car = a 9 sec pass Cheaper Fact! Lower the comp to match it also still = 9's with factory heads.
