What ignition coil has the hottest spark?
as far as plugs....best are copper or silver....only problem with copper is short life....silver....expense
plug gap is something you would have to experiment with to determine which gap suits your needs
The copper core does not matter. Electrons travel on the metal surface not through the metal. The iridium is carrying the current.
The copper core likely just allows the maker to use less iridium to make it somewhat cheaper than solid iridium.
mmm no they dont.
Solid conductors would be a bit pointless if electricity only passed over the surface. May as well make them hollow and save a fortune on material !
We run copper pipes from the transformer to the electrode leads and run water through the pipes to keep them cool.
Inside the transformer vault we use copper plate between taps.
Weird !...and I had never heard of that before and it certainly wasn't how my physics teacher taught us ! lol
Although maybe not quite as clear cut as that ?
http://scienceline.ucsb.edu/getkey.php?key=3199
As a state licensed electrical contractor, we have to have a certain amount of hours per year in classes for our license. I can’t tell you the number of guys at our classes that ask “why don’t the wire makers build hollow wire for better current conductivity and flow?” Classes are taught by the smartest electrical engineers in our areas, mind you.
Ive yet to find a teacher that can answer the question correctly. It’s the reason that stranded wire in the same gauge can carry more amperage than the same sized conductor in a solid. Surface area.
Originally Posted by sjsingle1
the reason OEMs use iridium is for their long life....not because it increases spark efficiency
Like I said some of you need to do some reading about spark plugs instead of showing your ignorance, GM ain't worried about your long life, all they got to do is get to the end of your warranty. In FACT the smaller iridium electrode is more likely to create a spark then a standard plug . Think about it if you can. How many times a minute is a plug told to fire. It does not spark every single time BUT if I can reduce that misfire it increases the power output Jeanne the fuel mileage.
