Burn muh stock ls3 intake can’t be beet!
Reveals what's really going on (and how plenum and runner length work)....Holley and CID can be worked further. LOD is great and covers all bases.. Sniper is a factory intake as the Hulk at cheap cost. Holley can also switch tops for 4150 or 4500 tops. Guys have many choices, which is great for us and 1's budget.
But the deal of the day is or was the factory intake after porting. 102 mm vs 92mm John B and a ported factory ls7 intake vs Beck's sheet metal. Once the sheet metal intake got the larger tb 102mm the difference was evident. Those guys do Nice port work with the factory intake,.....102mm would be a nice add
From: Coast of San Mateo County Between Pacifica & HMB
Big Hammer,
Thanks for posting , great data & very interesting.
The 102 TB gains in both tests were more than I would have thought.
Guess im going to a 102 on mine sooner rather than later.
Any one besides me think that the +24* exhaust split for a NA combo was extreme? 244*/268* on a 108* WOW.
I wonder why they didn't do mid & short runners with the FAST in the 2nd Test?
Have a friend doing a 447" with TFS LS3s & the LOD pretty soon, that will be revealing as well.
The following users liked this post:
64post (08-11-2019)
Not extreme at all for a drag oriented cam. For once we actually get to see an intake test wring the thing out to 8000 rpm that will actually highlight the differences between intake types.
The race runners in the Fast 102 would've been interesting to see on the final test. They had something like 16 or 17 different dyno results all requiring manifold and fuel system changeovers and tuning. I bet they just ran out of time/money.
I bought a CID from GPI after seeing the results. Stepping up from a victor Jr and Holley 750..expecting to pick up 40-50hp. They reliably see ~30hp gain from the CID over a Super Vic.
Bit of a one-sided test. Average power/tq readings were almost all done using 5600-7600 RPM.
Not everyone building an LS3 will want a camshaft that large, or care about 7000+ RPM numbers.
It should have been noted that the results should be considered for a serious or even max-effort build.
The following 2 users liked this post by big hammer:
Che70velle (08-12-2019), NAVYBLUE210 (08-12-2019)
