question about zero lash
Old Aug 24, 2019 | 11:55 PM
Mark_LSX's Avatar
Default question about zero lash
Im not sure if im goin crazy but i need someone to confirm;
With an adjustable pushrod length checker im measuring for pushrod length. With zero lash you can still pivot the rocker and compress the plunger on the LS7 installed lifter. This will go away once there is oil pressure, correct ? Im just adding .070 to zero lash and when the lifter is pressurized the remaining slack will be gone ?!
Old Aug 25, 2019 | 09:31 AM
TurboTim's Avatar
Correct
Old Aug 25, 2019 | 10:46 PM
Mark_LSX's Avatar
Originally Posted by TurboTim
Correct
thanks
