1/2 starter spacer w McLeod flywheel?
ls3 starter - Delco 12617229
QuickTime scattersheild
McLeod Billet steel flywheel 168 ring gear 6405507M
starter stout touched flywheel with about 1/2” to go. Do I have the wrong fly wheel or starter or is there a spacer ( not shim) I need for the starter?
The QuickTime scattersheild needs to be shaved at the top of the backing plate starter hole along with the bellhousing itself.
