Intake gasket or head gasket leak?
Looking for some help diagnosing a issue on a 5 month old built 5.3 liter. I have not took it apart yet but the problem is when it's cold it will back fire once and a great while(but only when it's cold). It has some white smoke that comes out of the exhaust when running, not alot and it often seems like it is running hot only when running at idle but smells sweet like coolant but I do not see any leaks. Just wondering if it is one of the 3 below. Thoughts?
- leaking intake gasket
- leaking head gasket (oil looks normal)
- or a cracked head.( heads are about 5 months old. and were properly torqued down.)
If exhaust smells like antifreeze, it's either a bad head gasket or cracked head.
Which heads are they? If they are 706, see if they are Castech heads.
They have a small battery-shaped symbol in the rocker area. They are known for cracking.
Go rent a block test kit at Autozone look on YouTube and see if you have exhaust gasses in your cooling system, it’s a simple test and will reveal plenty, Look at your motor oil as well, jack your car up, dump the oil ( cold ) into a clean drain pan and have a good look at it, see if there is water based contaminates in it, you can reuse it but you’re most likely going to be draining it anyway. Does you intake gasket have coolant running through it? Probably not. Backfire might be related to small exhaust leak somewhere and most likely to show up when your engine is cold, Running excessively hot is a sign air pockets in your cooling system or poor coolant circulation. Air pockets ARE introduced through a bad head gasket, just sayin. Good luck
The following users liked this post:
G Atsma (04-05-2020)
64post, thanks for the insight. I am hoping that's all it is. I will do that if it is in fact just a head gasket and since I will have it tore apart. Would you recommend replacing the lifters since I am already going to be in there even though they dont give any hint of issues at the moment? Again thank you for the feedback!
Seabee (04-08-2020)
Thank you, yeah I figured it would probably be wise to switch the lifters out since I was already going to be into the motor. Yes I have torque to yield bolts for the heads and will use new ones. Thank you all for your time and feedback.
