Shock
Old Apr 30, 2020 | 01:54 PM
Ridgeback08's Avatar
Default Shock
I'm in need of help please. 2002 Trans Am with LS1 has an electric pulse coming from the passenger side valve cover. I looked and did not see any loose or bare wires but it has to come from somewhere. Driver side is normal but passenger side has an electric pulse when I touch it. I know it sounds weird but has anyone else had this issue before?
Thank you
Old Apr 30, 2020 | 02:05 PM
RB04Av's Avatar
Sounds like something to do with the coils. Probably either a bad one or a broken ground connection of some sort.
You could swap the entire assembly from side to side and see if it moves.
