AiM Digital Dash compatibility and custom CANBUS integration?
Old Aug 7, 2020 | 02:16 PM
tox's Avatar
tox
Default AiM Digital Dash compatibility and custom CANBUS integration?
I am installing an LS3 with a E38 and 6L80e and would like to use a AiM digital dash. I talked with them about compatibility between the GM CANBUS and their dash and they said there's only a limited set of data on the CANBUS that it understands out of the box. I don't want to run a second set of sensors just for the dash. I would like a full range of data off the CANBUS including:
  • RPM
  • MPH
  • Oil pressure
  • Engine temp
  • Trans temp
  • Current gear # (ie PRND654321).
  • Odometer/Engine hours
If I add a supercharger I will want:
  • AFR
  • Vac/Boost
I want indicator lights for:
  • Check Engine (from ECU)
Has anyone had experience with the AiM dash and GM CANBUS? Is this doable, or should I look into other gauges? I'm willing to pay someone for their time if they know what they're doing and can make all of this work.
