DBW throttle body options, LS2, stock computer
Old Aug 30, 2020 | 06:46 PM
general23cmp's Avatar
Default DBW throttle body options, LS2, stock computer
What are the options for someone needing to replace their stock TB? I don’t mind wiring/harness changes, but would like to keep the computer as-is and stay DBW. Pull off LS2 TBs are going for a premium, and most are well-used. It’d be great to be able to go to something newer.
Old Aug 31, 2020 | 01:18 PM
ColeGTO's Avatar
Take your pick:
https://www.rockauto.com/en/catalog/...ttle+body,6472
Old Aug 31, 2020 | 01:41 PM
Originally Posted by ColeGTO
No, those are LS3 (gold blade), which I’ve read do not work. Can you confirm these do? I’ve also read that the off brand ones will throw codes.
Old Aug 31, 2020 | 04:02 PM
stevieturbo's Avatar
What vehicle, and what is the problem ?
Some guys...GTO's or Monaros have got away with the gold blade on theirs without issue. Although other vehicles seem less lucky.
Old Aug 31, 2020 | 04:10 PM
Never said I had any problem, really. Looking for an LS2 dbw alternative as I know LS2 works on my setup.
My setup is unique...2002 LQ9 factory DBW. A simple adapter harness allows me to use an LS2 TB just fine (simple repin). If something can use another TB as an alternative to the LS2 one, without reprogramming, it should be fine in my application.
Old Oct 8, 2020 | 10:28 AM
qwiketz's Avatar
I'm in the same boat retrofitting to a 8.1l 496. I will be using a specific harness and if I get a gold blade or non silver blade equivalent, I'm going to be in for a world of hurt.
The electronics and how it reads is what we're after. What has the same style of electronics on it as a silver blade ls2?
