High volume water pumps
Old Sep 7, 2020 | 01:19 PM
Skydawg's Avatar
Default High volume water pumps
Although this topic has been addressed in other threads, most were quite old and referenced products that are no longer available. So wanted to maybe get some updated options and opinions.
heres the deal, I have a LS3 on a Cessna (long story) and want to increase cooling efficiency at lower RPMs. It seems most of the aftermarket pumps are little different than stock, and any meaningful increase comes mostly from speeding pump up by changing pulley size. Anyone have some actual experience and real results with swapping to a “higher performance” pump?
i reference electric pumps have better low RPM performance, but being on an airplane it is another potential point of failure.
Old Sep 7, 2020 | 04:43 PM
spanks13's Avatar
At higher rpm the mechanical pumps way outflow the electric ones.
Can you pulley it up?
Old Sep 7, 2020 | 07:32 PM
What is the max operating RPM in flight?
Old Sep 8, 2020 | 12:20 AM
Skydawg's Avatar
Max engine RPM 3300, so well below max performance of pump. My next mod will be changing pump pulley to smaller diameter with stock GM pump. I can’t seem to get any real performance comparisons with after market pumps and some seem China quality. I’m using up to a 22 psi cap to compensate for lower ambient pressure at altitude, so don’t want any seal leaks from a cheap pump.
on the ground is challenge due to less air flow.....really had to make some compromises with coolant drag coefficients.....so would really like to increase flow at idle as well.
Old Sep 8, 2020 | 09:59 AM
I would decrease WP pulley size so that the pump is running an RPM equivalent to running at about 4400RPM, or about 33% faster.
What else is running off the accessory drive? An alternative would be to increase crank damper size a like amount so that the alternator is running at the same equivalent RPM, though I doubt that is a critical consideration.
Old Sep 8, 2020 | 10:33 AM
Skydawg's Avatar
Thanks. I was hopping to find some graphs depicting stock GM pump flow vs. RPM, and compare to the aftermarket pumps marketed as high flow. Is there any supplier of different sized pulleys that can directly replace the stock GM pulley? What’s required to pull the stock pulley and replace it.....most OE pumps are more permanently mounted and not so easy to modify. Seems like path of least resistance is changing crank pulley?
as far as alternator goes, it’s turning well below it’s max with the reduced engine output, so no issues there. I may add air conditioning compressor later, but again, over speeding with the crank pulley shouldn’t be an issue in terms of exceeding accessory limitations.
Old Sep 8, 2020 | 10:43 AM
SLOW SEDAN's Avatar
Why not run redundant Davies Craig EWP pumps? They are an OEM supplier and a good bit cheaper then meziere and other options, been using mine for years without issue but having two would basically negate any potential in flight issues.
Old Sep 8, 2020 | 11:19 AM
Skydawg's Avatar
Thanks for suggestion. Adding extra stuff becomes complicated with FAA, especially aftermarket stuff that has no standardized QC program, such as GM has. Redundancy is always good, to a point....engineering protocol On planes is mostly considering adding potential points of failure vs. the benefits. Mechanical pumps are pretty reliable and failures usually are not considered critical enough to warrant adding an electrical WP and it’s possible points of failure.
Old Sep 8, 2020 | 01:06 PM
SLOW SEDAN's Avatar
That's why I mentioned they are an OEM supplier to many vehicle brands (including GM) as well as Siemens equipment so they have been QC tested in similar manner. Either way if its not worth it so be it. However, on that note if an electric water pump is a potential point of failure then a mechanical thermostat probably is as well as I've seen those fail more often then a DC pump. Same failure point could be said for some of GM's lifters, but you have an LS3 so you should be good on that.
Old Sep 8, 2020 | 02:22 PM
Double06's Avatar
You mean like this one.
Old Sep 8, 2020 | 06:00 PM
Kfxguy's Avatar
if you do change to a smaller pulley, I'm interested to see what you end up doing. I need to do the same thing in my car, runs hotter at low rpm idle due to an underdrive pulley
Old Sep 8, 2020 | 07:04 PM
Old Geezer's Avatar
Anything here?
https://www.stewartcomponents.com/
Old Sep 8, 2020 | 07:44 PM
Originally Posted by Old Geezer
I looked- no LS pumps that I could see
Old Sep 9, 2020 | 04:09 AM
Mickyinks's Avatar
Im running an evans water pump, they upgrade internals , pumps 25% more than stock. You may even be better of using there waterless coolant as well, no pressure in cooling system
Old Sep 9, 2020 | 09:22 AM
Skydawg's Avatar
I could not find if Evans is still making pumps. As far as using their waterless coolant, we had to redesign our radiators that were dual pass due to the restrictions which proved too restrictive for efficient flow..... will be trying single pass design in. A few months. It seems path of least resistance is changing pulley, either larger crank or smaller pump pulley, with stock pump. Then maybe try aftermarket pump. Thanks for all the input.
Old Sep 9, 2020 | 09:48 AM
Kfxguy's Avatar
please post up what you come up with for smaller pulley. I was considering buying a press on hub (or making one) that has a bolt pattern. Then machining a solid billet bar into a pulley. But I really don’t feel like messing with the mess it makes in my shop.
Old Oct 25, 2020 | 01:12 AM
fastsspr's Avatar
Hell. you have pictures of your EWP set up installed?
