$1200 budget rebuild
This is what I have:
- Gen 4 5.3 block and crank-both honed/polished/checked by a builder. Cam Bearings installed. New freeze plugs installed.
- Floating rods (with only 7 good pistons!)
- 799 heads w/ valve job. (Cam kit springs installed and height matched)
- BTR Stage 2 cam kit (no lifters)
- Timing chain set
- Set of stock-bore pistons w/ rings
- Main Bearings
- Rod Bearings
- Oil pump
- Lifters
- Gasket set
- Trunion kit or Michigan Rocker Arms.
