"low-mount" belt tensioner?
I have an LS3 water pump on an LS1 engine, with Corvette spacing, and I'm looking for solutions to free up space for a custom-mounted Procharger. I'd like to free up room where the current KaTech manual tensioner and pulley is, by moving the tensioner pulley lower. So far I haven't found anything off the shelf, but figured I'd make my own if I couldn't find anything.
Pic attached showing approximately where the pulley would end up.
Anyone know of a good DIY design to make this work, or wanna point me to something already out there?
Thanks!
Thanks!
Im looking at older style tensioners, think vortec era small block to gain clearance at the frame on low mount a/c on an LS swap. Single bolt mounting with pin. Many pulleys available from grooved to flat and shouldered. Depending in pulley bolt hole diameter, may be able to swap the LS pulley in this style tensioner
No idea if the spacing would work for you, but they dont cost much, pick one up locally and take back if needed.
would replace this pulley and may tuck in better to prevent cutting as much of a frame notch.
Thanks for sharing this!
I don't have AC so not sure that routing would work for me. I'm a bit closer to DIYing this and I'll be sure to post up the final product.
that style of tensioner can be mounted anywhere. Spacing dependent, a plate mount for the single bolt and pin. Im just not sure how far it would sit in or out to line up with your set up.
