Dipstick tube stuck in block
Old Feb 21, 2021 | 09:44 PM
JonAdkins's Avatar
Default Dipstick tube stuck in block
Was putting headers on my buddies 08 Silverado and the dipstick tube broke flush with block, I've searched around and tried everything short of tapping the rest of the tube into the oil pan and removing the oil pan. What's my best option to get this fixed?
Old Feb 21, 2021 | 09:49 PM
Find a piece of very stiff wire, bend a very sharp hook into it, enough so it will slip down the tube, and see if you can pull the tube out. I just thought of, do not know if it works.
Old Feb 22, 2021 | 11:58 PM
JonAdkins's Avatar
Well, nothing we tried work, even the hook method, couldn't get anything stiff enough. Put a small bolt and washer over it to keep it from leaking and drove it the shop, gonna let them mess with it. Hopefully that won't be an expensive endeavor.
Old Feb 23, 2021 | 01:41 AM
QwkTrip's Avatar
I wouldn't do that. Who knows what the hell they'll do and leave in the oil pan.
One of the golden rules I've learned over the years is nobody cares more about my junk than I do.
Old Feb 23, 2021 | 02:15 AM
JonAdkins's Avatar
Ain't that the damn truth, it's why my car doesn't ever see a shop. But ultimately it's not my decision since it's not my truck.
Old Feb 24, 2021 | 08:54 AM
Old Geezer's Avatar
Lightbulb
Take the pan off, and knock it out....Not rocket science.
Well, maybe, for some.
Old Feb 28, 2021 | 04:29 AM
Jontall's Avatar
You could try a greased self-tapping sheet metal screw to get it out. Carefully thread it in and use a slap-hammer or a vice grip pliers to pull it out.
Old May 23, 2021 | 08:13 AM
indyjps's Avatar
yes this. I was planning on a greased tap and thread a bolt in and a slide hammer. Havent done it yet.
Old May 23, 2021 | 10:33 PM
wannafbody's Avatar
Would it be an issue to punch it into the oil pan? Isn't there a screen on the pump to prevent it from getting sucked up into the oil pump?
Old May 23, 2021 | 10:52 PM
QwkTrip's Avatar
Might land on the windage tray.
If there's line of sight from oil drain plug to oil dipstick hole, then you might be able to catch that sucker with a strong stick magnet. But catching something on a magnet is a pretty good trick.
