Pcv / catch can setup
Cruise: You want to set up an air flow path that sweeps the crankcase. Vacuum is your friend in this situation. Air moves from High pressure to Low pressure. The High pressure zone is the outside atmosphere. And the Low pressure zone is the engine intake manifold (that's in vacuum during cruise).
1. Let fresh air come into the valve cover. Either take the air from the engine air filter box, or mount a filter to the valve cover. Both are sources at atmospheric pressure. It's more environmentally friendly to use the air filter box so that the engine burns any gases that vent out the valve cover.
2. Connect the valley PCV hose to intake manifold. This is the low pressure side that completes the air flow path. Air comes in the valve cover --> sweeps the crankcase --> travels up to the center valley and into the intake manifold. A catch can is used to intercept and collect oil that might come out the valley cover.
Full Throttle: There's no more manifold vacuum and the manifold is at the same pressure as the valve covers (atmospheric). The crankcase pressure goes even higher (more blow-by past pistons) and the crankcase gases & oil droplets spew out every orifice of the engine.... Valve covers, valley PCV hose, weak seals.... whatever and wherever it can escape. This is when venting the valve covers saves the day.
1. Racers will reconfigure the PCV. They unplug hoses from the manifold and add vents to both valve covers. The catch can is used to intercept and collect oil from the valve covers. Racers might also add a vacuum pump on the valve cover in order to evacuate the crankcase.
2. Street car will still have the PCV system meant for cruising. Crankcase pressure & oil droplets will vent out PCV valve, valve cover, wherever it can. This is when things get oily messy for some people. Most the oil will come through the PCV valve in the valley cover, so people tend to favor putting the catch can on that circuit. Valve covers have pretty decent oil baffling and very little oil is lost that way. More venting of the valve covers helps with the oil loss situation through PCV hose (uncorks the engine so crankcase gasses can escape through valve covers). The way the factory does it is the 1LE cars have a big vent that screws down in place of the oil fill cap. The vent has an oil separator and ties into the fresh air intake (air filter box). If the oil separator isn't enough and oil puddles out of the vent, then that's the time to consider a catch can on that circuit too.
If your answer is yes then run a sealed catch can off of one of the valve covers, "Usually the driver side as the newer LS valve covers had an orifice built into it" and then to the intake manifold or if you have a valley cover with built in PCV then run the sealed can between it and the intake manifold. If your running valve covers that just has a 3/8" line connect with no orifice then you may need to run an inline PCV valve and as for the other valve cover just run a 3/8 line from it to the throttle body or the air duct before the throttle body.
If your answer no then I'd suggest investing into one or two breather cans and running each valve cover to a breather can. I'm utilizing one breather can with 10AN lines of each valve cover on the 427 and other than having to drain water out of the can during the cold months all has been good.
