Holley LS valve covers
Old Jun 30, 2021 | 08:48 PM
vjjack04's Avatar
Default Holley LS valve covers
Anyone used these or some like it from Holley? My question is, do the coil packs, inside, at an angle go in different directions on each side of the engine? It seems they might. In other words, the 4 on one side point to the front and on the other side to the rear....I would prefer they all point to the rear so they all angle towards the back....on both sides,
Old Jun 30, 2021 | 09:56 PM
SAPPER's Avatar
The coils point in the direction of the plug angle. Besides, with the covers on, you don't see the coils.
Old Jun 30, 2021 | 10:42 PM
wannafbody's Avatar
Looks like you'd have to remove the plug wires and the cover to add oil. PITA
Old Jul 3, 2021 | 11:40 AM
vjjack04's Avatar
Sapper,
You are right. I should have known that, but for some reason thought the should all point to the rear; that wouldn't makes since. On another note, I found that the newer round LS coil packs (that came with my GM crate motor) don't mount on those valve covers. I called Holley and they confirmed this. I spent the good part of a day fabricating 8 little off set mounts to get the coils to align with the exit holes.
Wannafbody, removing 4 plug boots and the for bolts on the top is far from a pain. How often does one really need to add oil?
Old Jul 4, 2021 | 09:51 PM
wannafbody's Avatar
At least every oil change
