Lifter ?
Old Jul 8, 2021 | 09:25 PM
blackbyrd's Avatar
Default Lifter ?
The bird in my profile has been setting for several years. Finally get back to it and got her running but aside frommaome fuel leaks it's developed a lifter noise (louder then normal) on the driver side. I assumed it was bleed down from the amount of time it's been setting, but this evening I started and let it run till tstat opened up and it never went away.
Oil pressure is good 40psi @ idle, and revving didn't seem to build up pressure for the lifter.
​​​​do i need to let it run longer?
Old Jul 8, 2021 | 09:30 PM
Lifter is stuck. BTW this should be in Gen III Internal....
Old Jul 8, 2021 | 09:40 PM
blackbyrd's Avatar
You are correct got in a hurry
@TheBlurLS1 could you move this to the correct section?
Block is iron 6.0 but valvtrain is l92 heads for what it's worth
Old Jul 8, 2021 | 10:17 PM
1/2 and 1/2.... but should still be Internal....
Old Jul 8, 2021 | 10:18 PM
01CamaroSSTx's Avatar
Marvels Mystery oil to the rescue! Wouldn't hurt to pull the valve cover and check the rocker arm bolts to make sure they are torqued to at least 22 ft lbs.
Old Jul 8, 2021 | 10:29 PM
blackbyrd's Avatar
I was either thinking marvel or lucas treatment. But gonna pull the valve cover first. Cause it's loud almost like it's smacking the vale covers....
Old Jul 9, 2021 | 06:47 AM
SAPPER's Avatar
You can easily run an LS motor with no valve covers. Just remove them, plug in coils again and let hang down. we do it all the time when these POS trucks AFM lifters collapse, break springs, bend pushrods, etc etc.
Old Jul 9, 2021 | 10:41 AM
blackbyrd's Avatar
Clearer head and less caffiene........ I pulled the VC this morning everything was actually good torque was right
I have 3"tall valve covers and I flipped them and saw where the rocker arms were slapping the edges where it wasn't quite lined up right
