What's the proper application plus more
Its not gate keeping or goal tending. Its us measuring how serious you are about doing swaps before we pour a bunch of time into answering your harder questions later on.
Rick
Seems like if a 2.5 liter inline 4 cylinder fit then an LS engine with displacement from 4.8 liters to 7.4 liters of some sort can be swapped in with work. If it had a V8 or inline 6 an LS will probably physically fit.
Saturn Sky & Porsche 924 or 944 are two examples of 4 cylinder cars that can accommodate an LS swap. Likewise with a Pantera to Porsche 911 or Datsun 260Z etc.
Wiring harness, tuning can be a challenge.
Mating an LS to a non GM transmission can be a challenge.
Rick
The above is typical of those completely ignorant of their situation, yet will not do any homework that applies to their situation. His question indicates his supposition that LS engines come in different external sizes, which indicates he has done NO research into the matter. A bit pompous if you ask me.
Rick
BTW.....Welcome to LS1Tech!
Things you'll need to ask yourself before you ask any other questions:
1. What are my power goals?
2. Do I want to stay N/A or go forced induction?
3. What is my budget?
4. What transmission do I want to run - auto or manual - and more specifically, what model of auto or manual?
5. What is the year/make/model of the chassis I picked and what engine was in it last?
Once you start giving yourself a plan, then we can help answer more specific questions but if you're going to literally ask every question under the sun with the volume of information already out there covering that topic, you may not last here long and I put that in the nicest way possible. You can probably tell how much reading I do compared to how often I posted by looking at my join date versus my post count.
Last edited by SupaDoopa; Oct 18, 2021 at 11:02 AM. Reason: Misspelling - I'm OCD.
Not trying to criticise, just saying that if you're wading in thinking "I can build PCs, I've got this" then you may end up disappointed.
I'm unsure whether you want to do this as a business or for yourself, if for yourself, my first suggestion would be simply copy what everyone else has done. This will be a well trodden path, parts will be available off the shelf, will probably fit and work together, the problems will have been overcome and documented (on places like this) and you'll be far less likely to end up selling an "unfinished project" which amounts to a pile of expensive parts and a hollowed out shell after your girlfriend / neighbour / mum tells you it's been 5 years and you need to get that mess shifted.
In the meantime, there are loads of books on building LS engines, parts combinations, LS engine swaps etc. They're valuable resources, not necessarily to give you the immediate answer you seek, but you need some understanding and context of the actual complexities of the process you want to undertake, which is why people on here can't just give you a quick answer to such an open ended question.
There are threads with thousands of posts of people discussing how best to measure pushrod length, there almost invariably isn't a definitive "this is best" answer to any question you might come up with, the closest you'll ever get is "this is probably best suited to that application when combined with these conditions, but won't work well under these other conditions".
Also, you mention SS and GTSR W1, are you an Aussie? I have a few Holdens myself here in the UK, great cars
A personal side note - bigger isn't always better. I assume [and pardon my ignorance if this isn't the case] you went 454 because it's a pretty big engine. Depending on your power goals, going something more traditional i.e. 5.7L, 6.0L, or 6.2L is beneficial due to the plethora of parts available on the used market. While you can make just about any LS-based part work on any LS-based engine [with some exceptions], rotating assemblies are not universal and some head-packages work best on specific displacements. There is a lot of methodology and planning in this field that screwing computer parts together in a case doesn't prepare you for.
If you are just getting a bare block, disregard this follow up post. You'll have your work cut out for you and I suggest discussing your plans with a good, reputable engine builder.
