Head and Intake Question
I'd step up to bigger bore LS block like at least 4 inch 6.0/LS2 or a 4.065 bore LS3 block if wanting the big 2.165 valves. More cubes and less shroud of big valves!
On the typical aluminum block LS that has iron sleeves for cylinder liners - no idea how well notching would work. The notch for a 2.165 valve on a 3.80 bore might be pretty deep into the cylinder wall liner. Might work OK on an iron block LS etc.
