Fuel injectors
Old Mar 22, 2022 | 06:39 AM
Yoji h 123's Avatar
Default Fuel injectors
What is the horsepower rating for 320 Ib/hr injectors on a boosted and little bit of nitrous?
Old Mar 22, 2022 | 12:31 PM
theunderlord's Avatar
On a boosted?
need more info my dude.
Old Mar 22, 2022 | 01:11 PM
Yoji h 123's Avatar
Originally Posted by theunderlord
On a boosted?
Yes what info do you need?
Old Mar 22, 2022 | 01:59 PM
Yoji h 123's Avatar
On a boosted?
Yes. Like what?
Old Mar 22, 2022 | 07:02 PM
RB04Av's Avatar
ONE 320 lb/hr injector should be good for a bit over 500 HP, on pump gas, normal compression, yaddayaddayadda. Maybe 550. Would be almost exactly equivalent to 8 40 lb/hr ones. Wouldn't particularly matter whether a turbo or nitrous is involved. Power comes from burning fuel molecules, so if you put 320 lbs/hr of fuel molecules into a motor and burn it all and achieve typical heat —> work conversion on it, which is roughly 30 - 35% in anything resembling ANY production automotive engine, it'll make 320 lbs/hr of HP, no matter how you get the oxygen to it to combine with it.
Never seen any such thing though. I'm having a hard time imagining it. Seems as though it would be alot like the spray end on a garden hose. Care to elaborate?
Old Mar 23, 2022 | 12:00 AM
.....unless he meant that as the flow rating for an entire set... OR he slipped an erroneous zero on a 32# injector......
Can't fathom 320# injectors, unless it's a big pressure washer nozzle.... LOL
Old Mar 23, 2022 | 12:10 AM
Maybe he's got a boosted pressure washer, since when I asked him "on a boosted..... what?" I got answered by another question. .
top tip: when you ask a question here, be specific. Tell us way more information that you think you need to. You'll get better answers and help people understand what you're asking.
Old Mar 23, 2022 | 05:08 AM
Yoji h 123's Avatar
Okay thanks for the tip.
Old Mar 23, 2022 | 05:40 AM
AJT_LBA's Avatar
quick search
https://www.fueltech.net/products/ft-injector-320-lb-h
crazy that there is something that large and how it would be fitted, but to answer ops question
  • Tested and approved on +4,000 horsepower engines
Old Mar 23, 2022 | 05:45 AM
Yoji h 123's Avatar
Originally Posted by AJT_LBA
quick search
But here's something I forgot to mention is I'm going to use Bosch 210's on 101.5 psi fuel pressure which ups them to 320 Ib/Hr.
Old Mar 23, 2022 | 05:58 AM
AJT_LBA's Avatar
thats almost equivalent to what i found on fuel tech, but at 90psi. Flow is flow, the injectors will support up X amount of hp depending on your set up. Now, how long those Boschs last, i dont know, but that wasnt your question. Fueltech's calculator shows that at 90% duty cycle, 8 320lb injectors will support ~3900HP with a turbo
Old Mar 23, 2022 | 10:01 AM
OK, Yoji, just for entertainment's sake let's say you ARE actually using 320# injectors that will support 3900HP.
How much power are you actually dealing with here? What is the setup?
Old Mar 23, 2022 | 10:51 AM
RB04Av's Avatar
And just what size rubber DO you wear, anyway? Don't have to ask what you're doing when you wear it; no human female would participate in that, that's for sure.
Old Mar 23, 2022 | 11:23 AM
Yoji h 123's Avatar
Just a little over 1300hp lmg with aftermarket pistons and rods but stock crank
Yoji h 123's Avatar
That's not needed.
Old Mar 23, 2022 | 12:23 PM
So you're spec'ing injectors with 3 x needed capacity. The BIG question is.... WHY??
Old Mar 24, 2022 | 01:07 PM
RB04Av's Avatar
See post #13.
Old Apr 3, 2022 | 08:32 AM
Tin Indian's Avatar
101 PSI fuel pressure !
The operating pressure for the LS3 / LS7 is 58 PSI.
What ECU are you going to be using that will allow you to tune the engine while using 101 PSI of fuel pressure?
And, I have never heard of anyone using an injector capable of 320 Lb/Hr flow on an LS based engine.
Where did you get this idea from anyway ?
Old Apr 3, 2022 | 10:47 AM
LilJayV10's Avatar
Trollin.......
Old Apr 3, 2022 | 11:01 AM
Trollin.......
Looks that way...
