Need advice building a l92
hello guys im new to the forum and maybe this isn't the place to ask but i have a l92 that i was planning on rebuilding. It is from an escalade ext and the block has 150k miles on it. i was planning on doing a stock rebuild but decided i want to see some power or at least a built engine that can handle boost. so my question is what would be a good way to go about this? say if you had a l92 and give or take 6k to play with what would you do? what internals to get? pistons and rods? what should i get done in the machine shop?
Why are you rebuilding this engine? Is there anything wrong with it? 150k miles is nothing on LS engines. Keep it together and put a turbo on it. It won't cost $6k.
Welcome dude! this is the best place to ask, you did well.
You've asked an easy, yet tough question. basic answer: forged pistons, rings gapped for boost/power adder, forged rods, stock crank, stock heads, upgraded camshaft and valve springs.
150K engine rebuild (while you're in there) will need, new lifters, new lifter trays, new front and rear seals, obvs new head gaskets, oil pan gasket, oil pump oring, cam bearings (if needed), main journal bearings, intake manifold gasket, lifer valley (LOMA) gasket.
Machine shop minimums are; piston bore mic, hone to a finish dimension, main line bore. Once you get that piston bore dimension you can then order pistons to that dimension, then you can look at the crankshaft and order bearings for those dimensions.
So yeah, it's complicated. The $ aspect depends on where you live for machine shop pricing, and how spicy you want to get with those rotating parts. K1, Diamond, Wiseco, Mahle, would be my choice for those.
Awesome! Didn't expect a reply that quick this site rocks! Well I forgot to mention that I am swapping the l92 I had an extra sitting in my garage for a future project but the block on the engine my truck previously is cracked so I was thinking of rebuilding it since I really don't know how well it was maintained before I bought it! Figured if im gonna be adding boost later I might add some better internals . Should I keep stock size pistons? I just don't want it to blow when i add some boost.
The following users liked this post:
G Atsma (03-25-2022)
Building a L92
I built this what used to be a 07 Escalade ext L92 into a 416 stroker using summit racing Pro LS 416 stroker forged rotating assembly .
Stock L92 rectangle port cylinder heads with BTR high lift duel spring and retainer kit. BTR Stage 2 LS3 NA performance cam. Heads were decked for straightness and slightly raised compression to 11.3:1. Runs fine with Sunoco Altra 94 octane.
Summits forged H beam rods
The LS3 416 is nicely sitting between the fenders of my 81 NASCAR turbo Trans Am backed by a 4L70E 3000 rpm stall converter. All electronics are run with the Holley Terminator X max FI ECU.
VVT delete Comp cams true double roller timing chain… Melling hi volume high pressure pump. I needed to remove some material from inside the timing chain cover for the cover to clear the oil pump bolts.
