Gen 4 E38 ECM Pin 52 Starter Enable
Old Apr 6, 2022 | 01:44 AM
Lance777's Avatar
Default Gen 4 E38 ECM Pin 52 Starter Enable
This is in reference to gen 4 wire harness pin out. LT1swap.com has pin 52 (starter enable relay) as yellow highlight/remove but also says underwood C5. So I'm at the point of trying to start. I am not getting spark on cranking. Code P0615 pops up, a starter relay code. I'm not getting any spark on cranking. Pretty sure Yellow highlight is suppose to be blue highlight/ move elsewhere in instructions. So if I put that pin back in, where does that wire run to? Relay and which part of relay? I.e. where am I wiring it?
Thanks.
Lance
