Cab swapping a 2010 chevy 3500
Old Sep 20, 2022 | 08:37 PM
Clyde51vt's Avatar
Default Cab swapping a 2010 chevy 3500
Hey guys and gals. I'm new here. Anyways I just got the running and driving chassis our of a 2010 chevy 3500 cutaway bus with a l96 vortec and a 6l90e trans. I just ordered a standalone harness that runs the engine and trans. My question is, once the cab from my 1953 chevy is mounted on the chassis ide like to possibly put a 2 way momentary switch to run the manual up and down gearing like the oem shifter handle had but mine will have a stick shift that runs the auto trans so it still looks like a standard. If this is doable, what wires or pins on ecm would I need to run to a switch? And does it get switched power or switched ground? Thanks in advance!
