Tips to loosening a Harmonic Balancer Bolt
Old Dec 12, 2022 | 07:50 PM
Lght Spd's Avatar
Default Tips to loosening a Harmonic Balancer Bolt
Taking the harmonic balancer of my 2005 LS2.
doing an A&A kit and it requires that the balancer and crank be pinned. So while I’m here I’m replacing the balancer with a new Summit Racing C2501. I’ve used a 1/2 drive breaker bar with no luck, afraid the breaker bar was going to snap it flexed so much. Then I borrowed a Makita Impact Gun with 740 Ft Lbs of torque (So Makita claims) an went to town with no luck. Any suggestions on how to loosen this bolt?
Old Dec 12, 2022 | 08:17 PM
Onbusy's Avatar
Hit it with the torch. I went to Lowes and bought a simple propane torch just for this. Heat up the bolt head and then hit it with the impact. I normally use the Dewalt 1/2" impacts (1400 ft/lbs break torque), but the Makita should be able to take it out as well. I've never been able to break one with a breaker bar/ratchet, you really need the impact for this bolt.
Old Dec 12, 2022 | 08:59 PM
wlink14's Avatar
Are you using good quality impact sockets?
Something about the rotational weight of the impact socket really allows the impact to go to town.
+1 on ditching the breaker bar
Old Dec 12, 2022 | 10:54 PM
Lght Spd's Avatar
A drive down to Home Depot and a $25 investment into a propane torch and a couple passes over the bolt yielded me the end result I was looking for. A extracted balancer bolt. What is that orange/red compound that’s at the backside of the flange head? That stuff I’m guessing is what kept that bolt on as good as it stayed on. Great Compound.
Follow up Question?
Putting a ARP bolt back in. Can I use the Makita impact to reinstall the bolt? I see the torque spec calls out 240 ft lbs. I looking for the easiest way to get to 240 as possible?
Old Dec 13, 2022 | 01:42 AM
QwkTrip's Avatar
You need to think more like a lazy guy. A breaker bar and a floor jack. That's all you need to break it loose.
As far as tightening, get a proper torque wrench. It's not cheap, but a proper tool makes the job easy. And it will be handy for larger bolts in the suspension system too.
Also, DO NOT use the bolt to install the damper. The bolt is too short and you'll strip the threads inside the crank. Get a piece of all-thread and use that to get things started until you can get enough thread engagement on the bolt to use it to seat the damper the rest of the way.
Old Dec 13, 2022 | 01:02 PM
Lght Spd's Avatar
Thanks for the info, I appreciate it.
I purchased a Summit Racing Balancer Installation Tool https://www.summitracing.com/parts/sum-900135
My real concern is how the hell I'm gonna reach 240 ft lbs of torque with a breaker bar that flexed like a spahgetti noodle. I have access to a Cornwell 1/2 Drive Torque Wrench with a 250 ft lbs capacity.
Old Dec 13, 2022 | 02:28 PM
01CamaroSSTx's Avatar
Find yourself a piece of thick walled steel pipe big enough for your breaker bar to fit into and do what was mentioned in post #5 "Use the floor jack to help break the bolt loose or get a long enough piece of pipe so you can put some more man power into it"
Old Dec 13, 2022 | 02:35 PM
bthomas's Avatar
Old Dec 13, 2022 | 05:15 PM
QwkTrip's Avatar
You get a proper torque wrench that indicates tightening torque within its capable range. The handle will be long enough that your weight will do all the work. Again, think like a lazy guy.... that's where you'll get all your best ideas.
I have a buddy that was putting all kinds of effort into turning the crank bolt. I gave him my Snap-on 300 lb-ft torque wrench and flywheel blocker and he started laughing how easy it was to tighten the bolt. No struggle at all. Lean... click. Done.
Impact wrenches are useless for setting final torque. It's not a precision tool, it beats the living **** out of the bolt and tightens it more with every pounding. You NEED a torque wrench to know when it is PROPERLY tightened dynamically (while rotating, not static). Don't listen to yahoo's that tell you otherwise.
Old Dec 13, 2022 | 05:29 PM
TrendSetter's Avatar
Originally Posted by bthomas
this. last balancer i had to remove only took like 4 uggas.
Old Dec 13, 2022 | 05:52 PM
Lght Spd's Avatar
Thank You Sir! Sage Advice.
Old Dec 13, 2022 | 11:54 PM
QwkTrip's Avatar
That photo is hilarious!
I'm still cracking up after seeing it 3 or 4 times. LOL!
Old Dec 14, 2022 | 11:01 AM
LS1Formulation's Avatar
The orange compound is a special threadlocker GM has that is solid until torque is applied, then it liquifies ( so they say ). You can just use regular threadlocker when reinstalling.
Old Dec 14, 2022 | 12:04 PM
ddnspider's Avatar
This^
Old Dec 21, 2022 | 12:25 PM
Sturdy's Avatar
You've got it off now, but for other's reference in my experience you 100% need a load of heat on the stock bolt to break that orangey/red locking compound, then it comes off pretty easy.
Half the stuff I've read people read 240 ftlbs as "as tight as you possibly can" and leave it at that.
Old Dec 21, 2022 | 04:47 PM
Well, I just buzzed the balancer bolt off my LH6 with an electric impact a few days ago and didn't need to heat it at all. Definitely hadn't ever been removed in the last 16 years either. I have yet to find a balancer bolt that won't budge, but I also could go buy a lottery ticket and win, too.
Old Dec 23, 2022 | 06:02 PM
Lght Spd's Avatar
The Red/Orangey compound is no joke.
